Deems RV10 Project
Date: 6-3-2008
Number of Hours: 7.50
Manual Reference: Sec Home-67
Brief Description: Sec Home-67
I finished off installing the Cannon plugs and the rest of the wing root connections yesterday and today. I also fixed some mistakes in the cable/wire routing, I had run the aileron trim cable to the right wing instead of the left wing, so I had to undo that from the hatswitch relay deck, and undo it from the right side wire/bundle. I also had to fabricate the harness to connect the roll servo located in the right wing to the programmer. I found a wiring problem with the servo harness a the time and corrected that as well. When both of those were ready, I moved the trim cable to the left side of the fuse, while running the Roll servo cable up the right side, and securing it all with Ty-wraps. I also made a mistake when initially installing the cannon plug in the right side, by initiall instaling 'socket' connectors on the wire ends instead of 'pins' so I was short of sockets when doing the Left wing and had to pick up some extra @ Aerozona this am. I installed the 24 pin cannon plug on the left wing. I debated about the pitot LED harness, and in the end I decided that I would include it in the harness and bring the LEDS into the cabin, I'm still not sure I'll install them, but if I Do want to at least that option is open. Put the connon plug and connectors on the fuse side, I included the ray allen 26 awg wires as well and even with the right connectors, that was a challenge. Installed BNC for the NAV antenna. I also installed a previously ordered a bulkhead elbow fitting for the Pitot tube connector.
All connectors installed on the wings
Right side 16 pin Cannon plug and marker beacon BNC
Left side 24 pin Cannon plug, NAV BNC, and Pitot quick connect fitting
Copyright © 2001-2020 Matronics. All Rights Reserved. |
