Deems RV10 Project
Date:  5-20-2008
Number of Hours:  3.00
Manual Reference:  Sec Interior-18
Brief Description:  Sec Interior-18
I finished masking the windows on both doors, and filled and sanded any remaining flaws that I could detect, and then fired up th ecompressor and the Harbor freight spray gun, and proceeded to shoot the perimeter of both doors, I applied 3-4 coats to each door, and then left them out in the direct sunlight to 'bake' throughout the day. I ran ang got on of the upholstered panels and put it in place on the door , and it looks good, I can live with this! Spent the rest of the afternooon fitting the glareshield I got from Greg Hale. I needed to buildup/extend the sides a bit in order to fit my panel, and so I attached an 8ply lay-up to the right side, and through a series of sucessive trial and error fittings, I trimed the extension so that it fits fairly well. i'm still going to have to do some cosmetic work to blend it into the door/cabin cover post. I started to think about how I'm going to attach the glareshield to the upper fwd fuse. Greg made it so that there's a slot that slips under and on top of the upper fwd fuse. If I can get the underside of the glareshield to fit flush with the top of the panel, I think I can use some type of blind floating nut/nutplate and screw into them from the underside, probably 3-5 blind nuts placed equidistant. Then I'm thinking of fabbing 2 'tabs' that extend 1" from the front of the glareshield and use those to screw it to the upper fwd fuse. I can use the access covers to get nuts on the screws. and the tabs should get covered by the dash cover I'm planning on installing.
Door perimeteres painted with interior paint
Upholstery panel trial fit
Fitting the Greg Hale glareshield
