Deems RV10 Project
Date: 3-31-2008
Number of Hours: 1.50
Manual Reference: Sec Home-48
Brief Description: sec Home-48
I finally got the garage washed out, and all (most) of the dust settled. I even used Judy's duster to dust the airframe and wings! I remounted the Horizontal Stab, and found out that the ELT antenna wil NOT fit in the location I have it mounted, I'll investigate the possibilities of a "rubber ducky" to see if that's an alternative, I'm certainly NOWHERE qualified to design/make antenna choices so this should be interesting. Remounted the Vertical stab as well, and then went searching for the various parts that will be needed, (I haven't touched these pieces in over 1 1/2 years!). Fortunately I found them all! I cut the rubber gap seal material to fit the closeout piece under the Horiz stab and then clecoed the lfet and right pieces in place. These actually fit very well and provide a nice weather/water seal. I slipped the fiberglass fairing on just to see how the initial fit ws, and it looks pretty good, hopefull the trimming and final fiting won't be a bear. I'm recovering from a cold that's gone thru the family and didn't get a lot done today, More to come tomorrow.
Garage ceaned out, and A/C repositioned to allow room to reattach empennage
Horizontal and Vertical stabs reattached
Bottom fairing and rubber gap seal clecoed in place.
Copyright © 2001-2020 Matronics. All Rights Reserved. |
