Deems RV10 Project
Date:  11-30-2007
Number of Hours:  2.50
Manual Reference:  Sec Home-30
Brief Description:  Sec Home-30
An easy/short day today, I helped Judy and some women from church with their annual Christmas dinner for the womens group, Quiote and event! But it wiped me out ! Also had Parkers annual IEP review for his day program. Reassembled the hardware for the doors and then remounted them to the fuse. It seems like every time I moun these buggers they fit differently, at least the left door did this time, not a big deal but the latch mechanism was too tight. I want it on the tight side, as I figure it will loosen with use, but this was too much. some careful filing and emery cloth and its now acceptable. Then I positioined the magnets inside of the door latch pins and adjusted them for the Door Ajar warning lights. On 3 of the 4 doors I had to cut off some of the magnet so that it worked right. A bunch of trial and error fittings. But I'm very happy in that they continue to show the door is open until the latch moves into the 'over-center' position. i was worried that the handles might work themselves loos and open up in flight, but I talked w/ Gary F. who is flying with the same handles and he didn't think it was necessary, After refitting these, i tend to agree, if the handle should 'loosen' the door warning light will go On while there is still 1/8" of pin protruding throug the intercostal. and that doesn'lt take into effect the Riverhead capture fixtures that add another 1/4- 5/16". BTW I really think the Rivethead keepers ADD to the safety in that they help to guide/center the pins into the holes making it almost impossible to only get one pin latched.
Epoxying Left door warning magnets into latch pins
Ditton the Right door
Reinstalled the gas struts, no change in fit
