Deems RV10 Project
Date: 11-17-2007
Number of Hours: 6.00
Manual Reference: Sec Home-23
Brief Description: Sec Home-23
I'm in RELAY HELL !!! For some reason, when I get close to a relay things don't go well. This a.m. I began to 'finish' the installation of the Door Ajar warning system. I connected all of the Left door components per the schematic, when I tested them it wouldnt' work. I naturally assumed there was something wrong in my wiring, so countless hours and continuity checks later, I swapped all of the wires over to the Right door relay and Viola!!! another bad relay, Now what's the probability that of 3 relays I have in my possession I would find 2 of them to be bad within 3 days????? A quick trip to Checker Auto where I picked up another, back home with it installed another test and NO JOY ! IT turns out the there is a 'minor difference in the relay I need and the one @ Checker. More Internet research, I finally locate the right relay 30 mins away, another trip, back home, install, and........ NO JOY!!!!! ????? I started doing continuity checked on all of the components and it appears thet the Reed Switches which should be 'normally open' are closed?!?!?!? More research, found some replacements, another 1:30 into and out of town, and finally @ 9:00 pm I have the Left door warning light working per plan. The good news is that when I began relays and their function were a mystery to me. I now feel safe in proclaiming myself 'fully versed' in 12VDC relay operations and troubleshooting. In the process of getting everything to work, I broke the monting tab on the Right relay..... someday's it just doesn't pay to get out of bed.
Door 'open' and Warnding LED is lit!
Left Door 'closed' and LED extinguished.... whew !
The 'brains' w/ cracked mounting tab for Right Door : (
Copyright © 2001-2020 Matronics. All Rights Reserved. |
