Deems RV10 Project
Date:  9-8-2007
Number of Hours:  7.50
Manual Reference:  Sec Home-10
Brief Description:  Sec Home-10
I finished up the XM weather installation. The problems I had were due to not having activated my own account. with that done Thurs pm. Fri. powered everything back up and it works. Initially I had a problem with reception but I believe it's because i'm using 50ft of rg58 for antenna, and the db loss is too much. Since OP Tech doesn't support all of the overlays yet, I opted for the Aviator LT package, I can upgrade when/if OP makes the enhancements. I fixed some 'bugs' in the dimmer circuit, and added some 'miniturized' d-sub 9 pin connnectors to the 26 awg Ray allen trim indicators. I used the method in Bob Nuckols AeroElectric connection. Sat I set out to wire the annunciator panel lights. I've got each respective light wired or labled/tied off to it's source. The next task was to complete the wiring harness for each of the rocker switches. That required a quick trip to Aerozona for more wire! I also wired the Starter/Crossfeed; Main Master; and Aux Master switches. I've labled and routed all of the wires to either the left or right side and have the left side all tied and secured w/ Ty-wraps. There are a couple of sub-bundles that don't go left/right but go to components mounted on the upper fuse subpanel. Those got tied into bundles and labled to get connnected when the panel gets physically installed.
Center Console module wired w/ Trim indicator dsub connectors
Annunciator light 'panel' wired
Main 7 Aux Master switches & Starter/Crossfeed wired
