Deems RV10 Project
Date:  7-19-2007
Number of Hours:  1.50
Manual Reference:  Sec 47 hinge-1
Brief Description:  Sec 47 hinge-1
Installed the Hidden hinge keeper from Carbinge.com. i found out about these from Ed Hayden. They consist of a machined piece that's about .0275 in OD and is barbed so that it can be floxed into the front of the cowl. In this case the rings. Then there is a stainless steel rin that is slightly undersized from the regular pin that comes with the hinge. This ss pin is silversoldered to a threaded insert that gets threaded into the barbed machined fitting that is floxed in the cowl face. The threaded insert has a Hex key machined into the open end so that the pin and threaded insert can be secured in place. AFter the Machined barbed fitting gets cured. I fill fill the opening where it got inserted and it will get painted so that there will be only a small 3/32" hole that will be visible. I'll look for a small white rubber plug that I might be able to insert to fill the fole when the pins is inserted. Not only is this a fairly clean and attractive option, but it is TONS easier to insert and remove the pins than the James ' was of doing it from inside the cockpit using a drill with the pin chucked in it.
Left side Hidden hinge keeper floxed in place
Poor pic, but you can just barely see the threaded insert
Right side floxed.
Right side floxed.
