Deems RV10 Project
Date:  4-19-2007
Number of Hours:  6.00
Manual Reference:  Sec PP-12
Brief Description:  Sec PP-12
I've pretty much finished priming and sanding the aft cabin cover. There's some pinholes tht i filled on the left side that will need sanding in the am. But everything else is primed and sanded w/ 320 grit. I need to get the right door jam prepped tomorrow. That will require remounting the right door, as I built up the bottom of the door jam quite some time ago, but never sanded it down so tha the door would close and provide the right gap/seam. Once that's done I can proceed to fill and snad the door jam. the on to priming it and the windscreen frame. I finally smartened up and moved the plane out of the garage so that the dust stay's outside (Duh!)
Aft cabin cover priimed
All pinholes filled and sanded w/ 320 grit
Smooth as a babys bottom.
