Deems RV10 Project
Date:  3-23-2007
Number of Hours:  5.00
Manual Reference:  Sec 45-08 step 1-5
Brief Description:  Sec 45-08 steps 1-5
Mounted / Epoxied the Right Rear window in place. Cut out the plexi for the cabin door windows, prepped them by sanding the edges progressively w/ 100, 150, 220 grit paper, then began the process of applying the peelable protective covering to each side of the door windows. The Door windows seem to be thicker than the Rear windows, when test fitting them, they were flush to slightly above the surface of the doors without any shims, the rear windows were consistently beow the surface and needed shims, it looks like these will not require any shims, I used a Dremel to relieve the edges in the doors themselves where the window sits to make sure that there was no radius that would cause the doors to sit up proud, I also sanded off all of the Smooth Prime on the window flange so I'll get a proper bond with the epoxy. Then I taped both sides with 3M fine line tape and applied 4 coats of the peelable protective covering to each side of the door windows. John Ackerman is having a project open house at his home in Prescott tomorrow so i
'm going to head up that way in the am for his event and to see his project.
Right Rear window epoxied in place
Wide shot
Wide shot
Door windows prepped for install
