Deems RV10 Project
Date:  3-5-2007
Number of Hours:  3.00
Manual Reference:  Sec 48-finishing11
Brief Description:  Sec 48-finishing step 11
After seeing a couple of pictures of builders that integrated their lower gear leg intersection fairings into their main gear wheel pants. I decided that I'd go back and redo mine. So with the main gear halves screwed together, I screwed on the intersection fairings, marked where the split lines should be, and then removed them and split/cut them with a Dremel cut-off wheel. I used some fine line tape to mark the cut line, but got distracted for a moment and when I returned I enede up cutting one of them on the WRONG SIDE of the TAPE !@$#$#@%$%!E@$#!!!!!!!!. Oh Well, so Idid a quick repaie using some flox and a sinlgle ply glass patch on each side of the cut (fortunately I didn't cut all of the way through). I put the patch under the halogen lights while working on the cowl, and the other gear fairing. Using a combo of the old nuplates and screws that are there to hold on the fairing, I mixed up some flox.cabosil and attached both of the intersection fairings to their respective gear pants. I also floxed closed the aft seam which had previously been open to allow for intstallation . On the nose leg fairing, I needed to cut out a small portion at the top where it interferred with the center brace from the cowl, and also needed to patch a miss drilled hole.
Left gear pant w/ intersection fairing floxed
Both Left and Right and Nose leg
