Deems RV10 Project
Date:  2-16-2007
Number of Hours:  3.00
Manual Reference:  Sec 47-8a
Brief Description:  Sec 47-8a
Been down for a couple of days with a whopper of a cold. Not 100% but got back out today to see if everything still fit after riveting and prosealing the hinges. The good news --- IT does! the bad news --- getting the hinge pins in is a royal PITA. I can see why more repeat offenders are going to Camlocs. I went with the hidden hinge for appearance purposes, but..... So I spent most of the day working with the hinge and hinge pins to try and facilitate making them easier to insert and remove. The vertical side hinges are really NOT a problem. The upper aft hinges are a real bear especially where the pin meets the curve. I rebeveled the hinges around the curve and sharpened the point on the pin, applied a little teflon, and I can get them in with some 'encouragement' Taking the cowl off and on after paint is definately going to be a 2 person operation. The horizontal hinge pins get inserted from inside the cockpit, BUT... it's very difficult to get the pin to align with the 1st hinge eyelet. Solution, I got some 3/16" brake line that was flared, and cut the flared ends off, countersunk them a bit more, and the floxed them in position with the hinge pin inserted. This should make for a 'funnel' target when the pin comes out through the firewall. More good news, the front of the cowl has been off by 1/8" around the spinner. I took the mounting plate off and clecoed some angle alum and it brings everything flush. When 6 ply layups are applied to the lower half and then nutplates attached some #8 ss countersunk screws will bring everything up flush!
Everything still fits, but needs 'fine tuning' of edges
solution to make spinner ring flush
Solution for aligning the hinge pin when inserting from insie the cockpit.
