Deems RV10 Project
Date:  11-27-2006
Number of Hours:  3.75
Manual Reference:  Sec 45-doorgap4
Brief Description:  Sec 45-Door gap 4 L& R
I got a tip from another -10 builder re shimming the Left door, apparently several other builders have had to do the same, I experimented wiht some an washers and found a combination that brings the door up even with the Cabin cover, With that done I gave everything a good sanding to even the flox filler that I put on Sat pm. there are still some low spots both on the doors and on the cabin cover frame, some are caused by the clampng pressure when trhe doors were initiall fit to the cabin cover, and others ????? anyway, looks like this will save a day at least due to not needing to wait 8 hrs on epoxy to cure/harden. I marked the low spots with a sharpie and then applied some more flox mixture to then so it can cure overnight, Also didn't have to remove the doors to do this which saves some more time. Also touched up a few places on the Right door frame.
Left door low spots filled with flox
ditto
ditto
