Deems RV10 Project
Date:  9-27-2006
Number of Hours:  1.50
Manual Reference:  More check out
Brief Description:  Complete check out of panel components
The problem that I was having (persistent) with the intermittent error messages has vanished! I'm not sure whether it was due to the new harness that I built and installed for the AHRS or, if it had more to due with where I had the AHRS on the 'test bench' which is really a glass top kitchen table with HUGE iron support members. Any way I haven't been able to recreat the problem dispite having gone through 2 battery charges in trying. At this point everything on the OP Techs is working perfectly. The only grip I have is that the ADC (Shadin 200) takes WAY too ling to warm up initially. i've got an inquiry into OP to find out if there's an upgrade or anothe roption available. I've been able to get more acquainted with the system and was able to configure (temporarily some engine gages to see what/how they displayed. Several 'screen shots from some of the screens.
EFIS primary display
MFD showing Full Moving map
MFD display on Primary screen showing Approach chart
