Deems RV10 Project
Date:  8-23-2006
Number of Hours:  2.50
Manual Reference:  Wiring harnesses
Brief Description:  Harnesses for AHRS, Pitch Servo, & Elevator trim
All of my wire.cable orders arrived today and so I was able to put together the harnesses (ELT antenna, Crossbow AHRS, Tru Trak Pitch Servo, and Ray Allen Elevator trim) and to complete pulling the remainder of the wire/harneses from the aft fuse through the conduits. The only wires that remain to be pulled throught the conduits are the wing strobes which go back to the power supply and those will have to wait until I attach the wings. It's going to be a tight fit with the strobe wires. The last wiring/electric thing to do on this aft portion of the fuse is to crawl back into the tailcone and tiedown the ELT antenna coax, and the Ray Allen Elevator trim bundle.
ELT coax antenna made and installed
Crossbow AHRS HArness made and installed
Tru Trak Pitch servo harness made and installed & ELT antenna connected
