Deems RV10 Project
Date:  3-4-2006
Number of Hours:  3.00
Manual Reference:  Sec 28-4
Brief Description:  Sec 28-4 steps 1-5
Cut the control column mounts per plans and deburr (this is thick material and took a while) Prepare the fwd fuse sub assembly (L&R), bolt together a bunch of parts deburred edges as I went along, then match drilled all of the common holes.
Here's where the right sub assembly goes
Left side is a mirror image
