How to mount a fuel tank in less than 20 minutes. (Part 1)
What a shocking title isn’t it? Well, in order to achieve that, it takes a bit of planning of course but the magic trick that allows you to do that. What I came up with is simply the result of observation I’ve made reading and staring at logs and pictures from other builder’s.I’m not claiming any credit for this technique but at least this time one can read a step by step proceedure. And it works nicely.
To begin with, place the fuel tank flat on your workbench, top side up and install one cleco into the most forward hole. Then place a rib lining up the corresponding hole of that rib to the hole where the cleco sits. Then add two additional clecoes to that rib and proceed to the next one.
