Dugans' Skybolt Web Site
Date:  3-6-2011
Number of Hours:  1.50
Brief Description:  Engine Mount
Installed lower engine mount bolts. Because the lower leg holes were not perfectly aligned, I had to make two bullet shaped pieceso of 7/16 rod to drive through the holes to align the holes. But, this worked some, Still needed to use ratcheting strap to pull the legs in position.
