Dugans' Skybolt Web Site
Skybolt
Wing Preparation
Filled and blended areas around the joints using super fil to make good transition across joint. Prepare and intalled 6 hinges for upper wing. Torqued to 25 inch lbs. Polished hinges and cleaned before installing. Torque seal applied.
Skybolt Home
1531
Covering
60
257
EAA Tech Advisor Ins
195
Engine Cowl
Engineer, research,
257
155
Hardware
Sheet metal work
232
