Picture is of initial set of rigging boards. Big scare. Wing in obvious twist, or at least I thought so. What was happening ws that I had leveled the fuse expecting to rig the wings 1.5 positive. I learned from friends at biplaneforum,com that the airfram must be 1.5 degrees down to allow the uppers to be level during rig. Releveled the airframe to - 1.5 degrees and began readjusting the upper to make level and remove washout,etc. Clamped everything in place as recommended.
