Dave's RV-10 Build Log
Date:  5-26-2020
Number of Hours:  4.00
Brief Description:  Oil Change & Service Bulletins
Replaced the oil filter, which required a strap wrench to loosen. Tightened new filter with 1 turn after gasket contact. Safety wired filter. Installed 8 quarts of AeroShell 100 mineral oil.
Inspected WD-1017 Nose Landing Gear for cractks per SB 19-09-09. None found. Logged SB as complete.
Performed SB 00006 (Vans) / SB 2069 Rev A (Garmin). No part numbers found on any of the Kavlico sensors. Removed the oil pressure sensor to look for parn numbers and found no labels of any kind. Replaced the oil pressure sensor
Contacted Garmin G3Xpert via email. They said that the sensors are genuine, and should be fine. Checked pressures against part numbers from the original boxes the sensors were supplied with, and all pressures are below max range. No leaks found. Logged SB as complete.
Re-installed cowl.
