Brief Description: Modified Left Cooling Air Inlet Ramp
Modified left coling air inlet to better fit around A/C compressor.
Attached bottom cowl. Determined the amount the left inet ramp needs to be bent down. Drilled out all of the rivets holding the conical gusset CB-1002J and removed it. Drilled out all rivets holding CB-1002A ramp to CB-1003A ramp flange. Drilled out baffle fabric rivets as req'd to remove the CB-1003A front cylinder baffle. Folded the CB-1002A ramp down to meet cowl inlet ledge.
Trimmed the conical gusset to fit the new angle. Re-installed CB-1002A baffle. Riveted the ramp flange to the ramp. Riveted the conical gusset to the ramp & front baffle. RE-attached the baffle fabric to baffle using large head pulled rivets.
