Removed the foam block surrounding the inlet air transition formed with fiberglass. Sanded the inside of the transition, and then cut the back end of the transition to length. Installed the bottom cowl to confirm the length is correct with about 1/2 - 3/4 inch gap between the transition and the front of the filtered air box.
