Dave's RV-10 Build Log
Date:  3-19-2018
Number of Hours:  1.75
Brief Description:  Filtered Air Box Inlet Fiberglass Fab
Sanded the epoxy applied last session to smooth the fiberglass inlet to the FAB. While mostly smooth, there was a small divot in the top back of the fiberglass transition. Mixed up an epoxy/flox mixture and placed a small amount into the divot to fill it in.
Used excess epoxy/flox stiff mix to fill and smooth the edges of the NACA vent inlets installed previously using pro-seal. Also used a small amount of the epoxy/flox to fill a damaged screw hole in one of the wheel fairings.
Used straight epoxy to glue a foam piece into the oil door area where the hidden hinge will attach so that it evens out the thickness introduced by the foam stiffener installed onto the oil door.
Unpacked and inventoried the shippment received from Van's and from California Push-Pull cables.
