Dave's RV-10 Build Log
Date:  11-21-2017
Number of Hours:  7.25
Manual Reference:  FF2-10 thru12
Brief Description:  Baffles Fabrication & Installation
Continued fabrication of the engine baffles. Installed the rear and side baffles per the plans.
Fabricated the front inlet baffles, however did not cut the hole for the prop govenor cable as it will need to be moved due to the A/C Compressor location. Also didn't rivet the DL-03 vent to the inlet ramp as it may interfer with the compressor, however I did cut the hole for the vent flange.
