Dave's RV-10 Build Log
Date:  11-20-2017
Number of Hours:  5.50
Manual Reference:  FF2-7 thru 9
Brief Description:  Engine Baffles
Continued fabrication of engine cylinder baffles.
Installed cylinder baffles. Had to slightly enlarge the baffle openings for the two rear cylinder valve covers as they didn't fit over the covers. Also had to trim the right rear baffle at the base of the connection to the aft bracket CB-1007D to allow for proper fit as it was hitting the engine case and preventing the baffle from overlaying the left baffle at the bracket.
