Brief Description: Prep Rear of Engine For Installation
Installed the oil filter block with extension block onto the engine using Loctite 518 on both sides of both gaskets per B&C instructions. Tightened the bolts to the specified torque. Had to remove the back-up alternator to reach the oil filter bolts, then re-installed the alternator and torqued to specs.
Installed the engine speed (rpm) hall effect sensor into the vent port on the right magneto. Re-installed both magnetos but didn't torque them as they will need to be adjusted to proper timing once the prop is installed.
Installed the oil temperature sender into the oil filter block and safety wired. Installed the oil pressure sender and the fuel pressure sender into the manifold block at the top left of the firewall.
