Dave's RV-10 Build Log
Date:  6-6-2019
Number of Hours:  7.00
Brief Description:  Mag Wiring & Seat Heaters
Installed the magneto P-Leads to both mags, running them through the top middle firewall fitting to the area of the key switch. Pulled the center wire through the shield, insulated the shield with heat shrink tubing, and crimped #10 ring terminals to the center wire and shield for connection to the mag. After running the wires through the firewall, routed them to the key switch location, trimmed them to length, and installed #6 ring terminals for connection to the switch.
Traced the spare wires at each seat heater relay to the other end of the wires at the front left side using DVOM for continuity checks, and applied wire labels to each. Pulled each relay from it's socket and easily found one of the 3 wires previously run to each with contnuity checks, labeling that wire at the front left side. The remaining 2 wires from each were not to be found among the wires where expected. After much heas scratching, determined that one of the remaing wires to each relay has already been run to a separate ground terminal at the left side of the forward front seat support brace. Then determined that the remaining wire in fact doesn't connect to the relay, but instead is connected to one terminal in both heater pad connectors. Once I figured this out, was able to label the remaining wires and re-install the seat heater relays and wiring.
