Brief Description: Trouble Shooting Engine Start Problem
After discussion with Carl, decided that perhaps the left mag needs to be timed for 7 deg. after TDC, since it is labeled as 35 deg. retard. Tried starting but won't start on the left mag. Did get it running by releasing the key and it then started on the right mag. Won't run on the left mag only. When shut down engine by setting mixture to cut-off, engine continued to spin by starter. Was only able to stop the spinning by opening the master relay. There is either a problem with the starter relay or the ignition switch. Will trouble shoot tomorrow after engine cools.
Talked to Joe Waltz who said he set both of his mags to 25 deg before TDC and his RV-10 engine runs well. Will reset left mag to 25 deg BTDC tomorrow.
Installed DB-9 connectors on elevator trim servo wiring. Tested and calibrated.
