Brief Description: Seat Belt Bolts, Side Console Labels
Drilled, counter sink, and install the overhead bolts for the seat belts. Fabricated bushings for the overhead belts from aluminum tubing provided in the Van's kit.
Tried to fabricate additional bushings for the other belts from the tubing provide, but was unable to as drilling the center resulted in break through the very thin wall, making the bushing useless. Will probably just bolt the belts in place without using bushings.
Applied the labels provided by Aerotronics to the center console forward sides to label the front & rear heater controls, the parking brake control, and the alternate inlet air control knobs.
Laced stick grip wires in tunnel area.
Sanded lower cowl inside surface following epoxy application on the 12th.
