Continued to work on installation of the glare shield cover.
Cut out the openings on each side of the glare shield for the avionics/defrost fans using an exacto knive. These cut outs were not exact or clean, and will need to have a trim ring installed over them to make them look good. Two options for these trim rings could be to make them out of hardwood using a router, or to make them using a 3D printer. In eiither case they can probably be covered with the "leather" fabric to match to cover.
Trimmed a little bit more of the cover at the windscreen to better fit.
Glued down each side of the glare shield from the center section glued yesterday to near the outer edge using the contact cement. Left the outer edges for additional fitting and fine tuning tomorrow after the main top sections have cured.
Continued to cut and install the thermocouple wire to the EGT & CHT sensors.
