Mounted the spinner to the prop in order to accruately determine the spacing for the front of the cowl to the spinner.
Fit top cowl, aligning per the drawings and then trimming the back end to fit onto the mounting hinge attached to the fuselage. Used 1/8" thick pieces of plexiglass (previously trimmed from an old RV-8 canopy as practice in cutting plexiglass) as spacers.
Trimmed and clecoed both "10 Inlet Ramps" to inside top cowl. Fit the cowl into place, determined the areas needing to be trimmed to fit around the prop govenor and trimmed the left ramp accordingly.
Tried to fit the prop govenor control cable bracket to the govenor but it didn't seem to fit right so stopped for the day to do research on-line as to it's proper attachment.
