Brief Description: Second Epoxy/Micro Finishing Layer
Sanded the epoxy/micro layer installed last Friday.
Removed the electrical tape after the sanding and found that it had become embedded in the epoxy/micro in a few areas. Installed 2 new tape layers about 1/8" above the old one and then sanded out the areas of old tape that were embedded. Removed the tape and applied fresh tape in 2 layers in approximately the same place as the new tape applied earlier today.
Mixed up a 5 pump batch of epoxy/micro balloons, including black coloring. Decided to return to the black color to have the black showing along the line where the new tape is placed for a consistent look from inside. Placed the epoxy/micro and shaped/smoothed it with the plastic "scraper" and hand pressure.
Inventoried the alternator shippment from B&C received last week.
