Dave's RV-10 Build Log
Date:  8-7-2017
Number of Hours:  5.50
Brief Description:  Cabin Doors, Interior touch up, Nose Gear
Cleaned up excess epoxy from the center latch slot from gluing in an extra re-inforcing block last week.
Touched up the edges of the window cut-out on one door where not fully bonded. Applied an epoxy/cab-o-sil mix to the areas along the edge that had small gaps, pushing the mixture into the gap with a short bristle chip brush and then clamping with very small binder clips.
Sanded and cleaned up areas around the doors where the interior paint had been damaged while permanently attaching the cabin top. Then sprayed these areas with an etching primer from a rattle can. Applied 2 coats of primer.
Attached the nose wheel fork to the nose gear leg per the drawings. Did not have a spring scale to adjust the nut to the proper tension for turning the fork.
Did some preliminary preparation for hanging the propeller on the wall in a corner when it arrives.
