Taped the right door tightly to the cabin top. Dirlled the holes around the window flange on both doors. Removed and separated both door skins. Realized the need to prime the new aluminum parts received with the Finishing Kit, including the gas strut attach doublers.
Removed the plastic from aluminum parts received with Finishing Kit and prepared them for primer by sanding with red Scotch Brite pad.
Sprayed parts with the Sherwin Williams P60G2.wash primer.
