Trimmed the inner door skins, both the window opening and the outer perimiter.
Initiallly measured and trimmed the window on one skin based on the small joggle near the center of the window, but when comparing the resulting opening to the one previously cut in the outer skin it became apparent that I measured from the wrong joggle. After calling Van's builder assist to confirm this, I re-measured and cut the proper larger window openings.
After all skins trimmed, sanded the areas where the skins will be joined by adhesive.
When initially assembling the inner and outer skins using clecos, found that the two index holes in the top edges of the window openings do not line up between the inner and outer skins. The other 4 index holes line up as expected. Sent an email to Van's asking about this.
Spent the last 2 hours further organizing my parts trays for easier ability to locate parts.
