Dave's RV-10 Build Log
Date:  2-20-2020
Number of Hours:  4.25
Brief Description:  Installed Labels, Entered Set Points and Ranges
Installed labels on the spare switch, and on the knobs for the heaters, parking brake, and alternate air as the labels on the mounts is very difficult to see and read.
Entered alarm setpoints and normal ranges in PFD/MFD.
Found the communication problem between G3X and GTN to be reversed wires on the RS-232 link between the G3X/GTN and G5, causing the G5 to be trying to send on the same line as the GTN was trying to send on. Found it when I turned off the G5 and communications were restored between the G3X and GTN. Reversed the pins on the G5 connector which solved the problem.
Checked and found that both the pitch and roll trim servos are not working.
