Determined I had wired all the pressure inputs for UMA transducers instead of the Kavlinco transducers provided in the Garmin sensor kit. These sensors need 5 volts instead of the 12 volts . Moved the supply voltage pins in the DB connector. Sensors now working.
Found I had connected the GPS antenna coax to the video input on PFD-1, instead of the GPS input. Moved the connection and GPS reception now working.
Checked magneto grounds - both were gounded in any switch position on the ignition switch. Removed the right mag P-lead from the ignition switch and it's still grounded. May be due to rotation position. Will wait for help from Carl tomorrow.
Soldered wire extensions onto the elevator trim servo wires so that they are long enough to install a DB-9 connector to replace the mini Molex.
