Brief Description: Configuring I/O Channels. Diagnosing Elev. Trim P
Changed the configuration information for the RS-232, RS-422/ARINC, and Ethernet communications between LRUs and GTN 650. Found that Elevator Trim Tab no longer works. Diagnosed the problem and found a broken wire at the elevator trim servo connector. Started to replace this mini Molex connector with a DB-9 connector, as the Molex connector is not easily re-pinned and not as secure as the DB-9.
