Brief Description: Install Yaw Servo, F-1025 Rear Seat Side Covers
Installed the GSA 28 Yaw servo. This required crawling part way into the tail cone in order to attach the servo cable harness to the rudder cables. Checked rudder range of motion and found it is properly limited by the rudder stops and not the servo.
Installed the passenger warning stickers for the rear seat passenger on the tops of the F-1025 rear seat side cover panels, just above the USB and headphone jacks on each side.
Connected the headphone jacks sub-panels to the F-1025 side covers, connected the power wires to the USB jacks in the side covers, and installed the side covers per the construction drawings.
Removed flaps from wings to perpare for wing mounting.
