With PFD-2 still out of the panel, decided to check the circuit breaker and fuses for the seat heaters, which I suspected to be the problem. Removed the right side panel insert which holds the circuit breaker for the seat heaters. Checked the circuit breaker with the multi-meter and it is working properly. Checked each of the seat heater fuses and they are also fine. So re-installed the right insert, and then PFD-2. Problem must be in either the seat heater switches or other wires down stream from the fuses.
Removed the right side switch insert panel. Checked for power at one of the LED connectors and found proper voltage. Used a clip lead to short the other side of the LED connectors directly to ground (bypassing the GAD 27), and the lights lit up at full brightness. Had to reverse a few of the LED bulbs to get them all to light, but they are now confirmed as all properly inserted and properly connected to power with all properly connected to the ground side. So the problem must be in the wire to the GAD 27 or from the GAD 27 to ground block, or in the GAD 27.
Tried to configure the GAD 27 through PFD-1 setup, but it doesn't seem to be configuring correctly.May be best to update all the G3X software and try configuration again.
