Brief Description: Closed Right Section Panel, Started Center Breaker
Closed out the right section of the panel, including the #4 flat head screws on each side of the PFD opening. Used stainless steel screws since they are less likely to strip the head than the original brass screws provided by Aerotronics. Connected the LRU wires, including the individual ring terminals on the GDU 27.
Connected the wires to the right side switches.
Started wiring to the center section circuit breakers. Found that I was missing a power wire for the GMU 11 at the breakers. Found the wire at the wing root, but it was much too short, stopping just beyond the end of the side wall conduit. Used the original wire to pull in a new longer wire that will reach the circuit breaker and should reach the GMU once the right wing is attached.
Ran out of lock washers for the circuit breakers as several were dropped/lost during connections. Will purchase additional #6 stainless steel split washers from Home Depot in the morning.
(Stopped work early in order to meet with the flooring store representative regarding replacing the carpet in the family room with hardwood.)
