Moved the GAD 29 from side to shelf of left tray to allow for siide tray trimming and for 3" space required for Dsub conectors.
Wired left side switches. Noted in testing that the special avionics master switch N.O. contact doesn't work, however I'm not using that contact so this isn't a problem. (Avionics relay is wired to energize to open the relay and disconnect the avionics bus, so the N.C. contact is used so that the relay is energized when the switch is down/off in order to de-energize the avionics bus)
Glued "Caterpillar" bushing material to the edge of the sub-panel bottom to protect the wire bundles. Used JB Weld 5 min. epoxy to secure the bushing, using masking tape to hold it in place while the epoxy cured.
Soldered the pilot and copilot headphone and mic jacks to the shielded wires run for this. The jacks will be inside the arm rest of the center console, and will be attached to the center plastic bin once the center console is installed permanently.
