Added wiring to the diagrams for manual dimming light control for the PFDs, MFD, GTN, GMA, and GMC, controlled by the output from the GAD 27.
Added page showing Starting Switch and Magnetos interconnects with wire numbers.
Added ELT mini control panel wiring connection diagram to drawing.
Added page with USB Power outlet wiring diagram and wire numbers.
Made a few final refinements and then printed to a pdf file at 11" x 17" page size to print at Office Depot to make wiring easier due to larger print size.
Should now be ready to begin building the actual wiring harnesses.
