Finally opened up all the boxes received from Aerotronics and inventoried all the Garmin hardware. Set aside the GTN 650 kit to take to the shop in order to determine sub-panel cut-outs required.
Developed a better sketch of the modification required to the standard Van's fuel valve handle shaft in order to extend it to use with the Aerosport center console. Boxed up the shaft with a letter and sent it to Geoff Combs of Aerosport Products who will have the shaft cut and an extension sleeve welded over the cut area to extend the shaft to the required 6-1/16" length. Took the box to the post office and sent it 2nd day Express Mail.
