Dave's RV-10 Build Log
Date:  6-9-2017
Number of Hours:  7.75
Brief Description:  Tail Cone Wiring Harness
Created the wiring harness for the tail cone avionics. .Installed the 90 deg. connector for the Garmin GSA 28 Yaw servo. Installed the connector for the GSA 28 Pitch servo. Bundled the wires with lacing cord.
Installed wiring for the rear seat headset jacks. Created a separated routing for the headset wire across the fuselage in front of the rear seats (rather than bundling it with the wing lighting wires), which required installation of additional stand-offs and additional holes with grommets. Created heat shrink wire labels and placed then on the new wires which now run from the head set jacks location to the front control panel area.
