Made final antenna location selections, drilled mounting holes for the ELT antenna and both Com antennas. Will install the antennas just prior to closing up the tail cone.
Waiting for order from Aircraft Spruce with aluminum sheets to make up the reinforcement plate for the two GPS antennas before drilling mounting holes for them.
Need to identify different locations for the Transponder and ADS-B antennas than originally planned as the instructions with the transponder antenna says it should be at least 18 inches from any other metal protrudance. The location I had selected is much closer than 18" from the main landing gear legs.
Also pulled 3 conductor shielded 18 AWG wire into both wings for the Nav/Strobe lights. The wire originally installed in the wings was for a different set of lights than the AeroLEDs Pulsar NX that I purchased.
Dimpled/counter sunk and riveted the horizontal stabilizer fairings into place.
