Brief Description: Left Main Gear Preparation & Left Wingtip Smoothin
Sanded the epoxy-micro installed yesterday to smooth the connection between the wing tip insert and the left wing tip.
Made up the left main gear brake mount. Installed the wheel/tire. Counted 8 full turns of the wheel nut. Removed the wheel and reinstalled the nut, then drilled the hole for the cotter pin. Removed the nut and installed the axel extension to the end of the nut, using the after market turned aluminum extension purchased from Cleaveland Tool.
Started to drill the right side main gear for the brake mount but drill bit is too dull to cut. Will buy new bit and drill later.
Added addtional epoxy-micro to the left wing tip to further smooth the insert connection area.
