Brief Description: Continued Wing Tip Smoothing & Prep for Floor Rein
Sanded the epoxy-micro added to the left wing tip insert.
Painted the area of the sanded epoxy-micro with 2 coats of thinned UV Smooth Prime using a brush. Sanded the area after the Smooth Prime dried with 220 grit wet/dry paper.
Rung out the wires running down the right side from the panel to the tail cone. Added wire labels to each of the wires as they were identified.
