Completed fitting the right wing tip light cover. Trimmed and fitted the left wing tip light cover. Drilled and riveted the nut plates to secure both lens covers at the corners.
Trimmed the left side rear window plexiglass to the provided line using a Dremel tool with 1.5 inch metal cutting disk. Used random orbit sander with 80 grit sanding disks to further fit the window to the canopy opening.
