Unpacked, inventoried and put away parts purchased from ACS over the holidays.
Installed several access covers inside the fuselage, including the top front side wires covers, the step bolt access covers, and the A/C condenser fitting covers. Twisted the head off of one screw on the right side fitting cover. Was unable to remove the broken #6 screw using an "easy out" screw extractor. Had to drill out the rivets holding the nut plate to remove the screw, then replace the nutplate. Had to use pulled rivets as couldn't get the squeezer yoke into the opening to squeeze standard AN rivets.
